Limit of correction
  • Thread starter Thread starter rightonjoe
  • Start date Start date
R
rightonjoe
Guest
I want to change my limit of correction in closed loop. I change the numbers and apply and then save then but when I return to this screen the numbers have returned to the previous values. THANKS JOE
Are you on line with the ECM when you do this?
If not you would have to load the new file from your lap top to the ECM.
Take Care
limits of correction
Yes I'm on line and want to increase the limits of correction and then correct my V.E. tables thanks JOE
If you are online when you make changes, you don't need to save or reload a file for the changes to take effect. The changes are written to the ECU as you make them.
To make sure I understand you correctly, You are making changes while online and then you go back later and the changes don't seem to be staying?
