I am just trying to get this clear. The proportioning valve is right under the master cylinder, about 5-6 inchs. So the rear line is the front brakes. I take the line out that goes from the master cylinder to the valve, and install the soleniod right there. I am not shure because the instructions are not that clear. But it looks like the digram shows that I should take the lines out of the proportioning valve. Cap one and run a line to the soleniod. Then out of the soleniod I put a tee on and install the orignall brake lines on to the tee.
Any info would be great.
Thanks Postal
