While trouble shooting a line pressure problem I gathered this info.
10 vane pump
Stock pressure reg.
TCI Purple spring (275 advertised)
.300 Reverse boost valve
.500 Boost valve==245 PSI Max. line pressure
Switching to a .531 boost valve --all else beening the same==265 PSI
Looks as though the larger boost valve is worth 20 PSI, in my case.
10 vane pump
Stock pressure reg.
