Got one side of the frame cut tonight (Frame Notch). Cut it right up to the edge of the factory seam weld, you can see the full weld line/bead. I rolled the wheel opening lips prior to painting. Also trimmed and massaged the edge or the factory inter fender, BFH. After it's all said and done will a 325/50/15 fit with out rubbing? Hope I cut enough, I'm not really wanting to take it any futher. Planned ride hight is going to be some where around 25.5" to the center bottom of the wheel opening.
No plans to ever go bigger on a tire....
Thoughts?
Thoughts?
