List together of some the most commonly asked questions
Jerryl
Tall Unvaccinated Chinese Guy
Figure I would put a list together of some the most commonly asked questions.
Not trying to put anyone one down, actually contrary.
If I can gain understanding of all these issues, I may be able to get a good running car.
Maybe we can colectively keep working on some links to each of these.
Post the number, and a link to a thread to answer the question.
Here is a list I came up with off the top of my head;
1. How to set the cam sensor?
2. How much boost?
3. How to get rid of KR?
4. Best turbo?
5. Biggest turbo?
6. Which HG?
7. Bolts or studs?
8. Which fuel pump?
9. What oil?
10. Which plugs?
11. Best converter?
12. Stock or aftermarket ECU?
13. Crank but No start.
14. Stroker benefits?
15. Alky benefits?
16. Pump/Alky AFR target?
17. E-85 AFR target?
18. How much timing?
19. How much oil pressure?
20. Which tires . . . .?
21. Best springs
22. Which lifters?
23. Best radiator?
24. Best electric fans?
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
i put a duel core griffins radiater and 16in electric fan off evil bay "fan only" and went from 206 degrees on a hot day to 170 on the same day both with a 160 stat in ;)
As usual, good post Jerryl. I added Questions 25, 26 and 27.. Maybe add this as a sticky in HA Section
2. How much boost?
4. Best turbo?
5. Biggest turbo?
6. Which HG?
7. Bolts or studs?
8. Which fuel pump?
9. What oil?
10. Which plugs?
11. Best converter?
15. Alky benefits?
21. Best springs
22. Which lifters?
23. Best radiator?
25. E85 Conversion for HA w/parts list?
26. E85 Benifits and Disavantages for HA?
27. Scanmaster or POWERLOGGER?
28.
29.
30.
31.
32.
33.
34.
