List your Top 5 First Mods
1. Fuel Pump w/ Hotwire
2. TT Chip w/ Injectors
3. Body Bushings
4. Rear Seat Brace
5. Alky
Not a mod but get it running perfect first..spring cleaning, plugs, decarbonize, etc.
Ill squeeze them into 5 ...LOL
On a untouched stocker
1. Fuel Pump and HW, jump resistor on cooling fan, aux trans cooler and shift kit.
2. Scanmaster, oil, water and boost gauges, K& N cone airfilter and hard intake pipe and gut cat.
3. Timing chain, oil pump and Valve springs. Mileage will dictate the valve springs.....the plastic cam gear is most likely cracking at this point.
4. Injectors, chip and adj fuel psi regulator, boost controller or a adj wastgate actuator, body bracing (jounce bars and rear seat brace) and bushings.
5. Alky (25 psi) and drag radials.
this equals low 12 second car easily
Fuel pump with hotwire kit
Adjustable fpr
Scanmaster
Maf and translator
Alky
And if everything goes well number 6 would be brakes
