Little help, hotwire kit...
macatoni
Buick Powered
Ok so heres the rundown. My fuel pump died which means its time for an upgrade (its on a TTA). I ordered Racetronix's walbro 340 and hotwire kit. The kit is extremely well put together however it came with no instuctions and i cant find a set anywhere on the net. Skip foreward to today and i almost have everything put back together. Basically the factory harness goes from the tank and has a connector thats right above the rear end where the wiring goes inside the car. THe connector on my hotwire kit looks the same except one thing. So the stock connector is a three prong male connector with three sheaths covering the prongs. My problem is that the connector in the kit doesnt fit my stock connector. The Sheaths of over the prongs on the stock one are slotted so it will only go in one way. The outside prongs have a slit goin the same way, and the middle prong's slit is pointed the opposite direction. The racetronix kit's middle prong is not pointing the correct way and wont connect. Can i moddify it and make a little cut to make it fit? Or is that not the right idea....
David
David
Please contact support@racetronix.com before posting on the forum. Answers will flow much quicker dealing directly with our support dept. Thank you.
Sorry i had tried to contact you guys several times through email but i did not recieve a response, i was just seeing if anyone else had this problem...
David
