Lock-up Hanging
A
ADAMWE4
Guest
Lock-up hanging locked and unlocked.
After being locked for a min or so on the highway it stays locked for about 2 miles before it will unlock.:(
Also if I am "street racing" and then I want to lock it for cruising it won't lock.
It seems to be heat related.
Maybe the solenoid is sticking?
I am running a good tranny cooler and the tems out are only in the 60s and 70s now.
My only control in manual using the ALDL circuit.
The Felpro does not have Torque Converter control.
Has anyone had problems with consistancy using the aldl for Torque converter lockup control?
That is a good test but not to be run constantly that way. And yes , you got a bad tcc or valve is sticking in bore above tcc.
Bruce
WE4
ww.ptsnctb.com
Bruce,
How should I control my converter?
Felpro does not offer any control.
So right now I have a rocker switch connected to the ALDL to control my lock-up.
Any sugestions?
Adam
