If your talking about a FAST system, you give the log file a name and save it. Once it's saved you can go into Windows Explorer and click on Cal-Com and look for your saved file. It will have a dot log behind it and drag it to your floppy drive
If your using the Windows verson you still go to Windows Explorer and go to C-Com WP and look in the log folder and then drag it over to your floppy drive.
I hope that helps
