Cheeseburger
- Jan 25, 2004
Spent all day fart assing around with this throttle cable and it does not work as i feel it should.
Don't like the way it's mounted at the pedal, maybe you guys are taking your pedal out and modifying it to work?????
On mine the throttle wire is angled sideways to the firewall which is the only way you can get it on the pedal that i can see.
Now at the other end when you test the throttle, the cable does not go back straght, it just goes into a U shape.
On top of that the cable pushes the ferrule out as well.
Stock accufab return spring is a piece of junk as it does not close the throttle blade without helping it.The cable sounds like it is grinding when you push the gas pedal.
Stock cable worked as it should without a flaw, flipped the throttle body over so i can run an iac and cannot get the throttle cable to work properly.
