Lokar Throttle cable Install ?
KWIKR 1
I haven't taken mine out of the package yet . But.. do you need anything off of the stock throttle cable to install the Lokar cable ? like that little spring button thing thats on the pedal lever ? Installing Lokar cable on a Accufab 90 mm Ford TB . Thanks . any tips if any on install one will be very welcomed .
I would get the bracket that Champion makes. It is designed for this cable and TB
You won't need anything from the stock cable.
If I remember right, the regal pedal has a hole through it and the stock cable has a ball on the end. the cable passes through the hole. The Lokar cable has a billet slip on end that goes over a brazed or crimped ball on the end of the cable. That billet end has a cross shaft that is made to work with a lokar pedal. Although you won't use the billet end as it's designed, you will use it to keep the cable from passing through the stock pedal. Keep the billet end on the cable and slip the cable through the hole in the pedal. It will be obvious when you get under the dash.
