long block with 2 caps
Turbo Indian
worlds quickest 6cyl bird
long block, intake to oil pan
this is the motor that is in the firebird in my signature.
2 center billet main caps
fresh 107M .010 main bearings (coated @ Calico Coating)
fresh 6-3768 .020 rod bearings (coated @ Calico Coatings)
Calico Coatings
bored .010 over with JE pistons with file to fit rings
210-210 roller Comp Cams
Durabond cam bearings
double roller timing set
stock turbo rods
stock turbo crank
ported iron heads
Ferrea big valves
Comp roller valve springs
cometic head gaskets
ported to match stock intake
Harland Sharp 1.55 roller rockers
all port work was done by knperformance in Charlotte NC
ported, & powder coated black front cover
new GM waterpump
$5800.oo
10 passes on this motor since freshened up.
