UR50SLO
The Reaper
- Jun 12, 2001
Lance or anyone who can help. We are trying to tune this car for the first time. We have a problem with long spool up time and the Wide band won't match what is on the A/R table.
For example: anything above 2500rpm is set at 11.8 a/r
When we data record it says that actual a/r is 12.5
Timing we set at 19.5 anything above 3500 that works fine
Drivability just crusing around is very excellent. good throttle responce after playing with the tps/map adjusments.
Seems like the motor is not quite winding up as fast as normal.
We've only put 16lb boost to it. No popping/weird stuff.. clean passses. Any help with suggestions on how to get the actual to match what's on the a/r table and spool up time would be great!
86 Camaro. 237Cid buick, GN1 heads,.72mmPTE,THDP,Precision's Camshaft(non roller)CAS front mount,ACufb.70throttle body) Art car 3500stall and preped trans(200r) 9"Ford/3:89gears) approx 3200lbs.
