looking for mid to low 10's .. never ran my car yet whatelse do i need ??
stock bottom end? if you get into the mid to low 10's you wont be doing it for long
any video of this? Buick events you ran this at or more information about the car like weight, heads, and ci?
ive got the time slip and about 20 others from the start of the project till now ..i was off a bit from memory .. My et was 10.58 @ 123.95 ..1/8 was at 6.6691 @101.10 .60 was 1.4450. I was flagged for no cage.. The car at the time had just one seat in it and an empty trunk ..not sure on the weight .. But i am 220 if that helps .. Gearhead built long block with ported heads 100 pd springs ,pte slic,motron 60's, te-60 ,maff trans & lt1 mass ,rjc power plate ,pcv,boost controler , tt 100 octane chip, ptc 2800 ,lonnie diers trans with brake .and a bunch of other nickle and dime stuff , ive since added a full gnx suspention & dash . But the car is put away till next spring so i cant even see if it will hold more psi off the line yet .. I can only wish ..
