Looking for relay ends...
Rosey1968
I need to replace the harness ends/connectors that go into the a/c and fuel pump relays.
I did not see at Casper’s...
Thanks.
TTT - anyone?
I need to replace both of mine as well.
Amazon has relays. They probably have what you need. Or you could call John at Casper's.
TTT - anyone?
As a follow-up, in reading through the forums about wiring new relays/pigtails, someone posted that GM used black dielectric grease which hardened over time and one could mistake the hard crusty grease for burnt up connector or relay. He mentioned cleaning them gently with solvent. Well, I looked at both my fuel and A/C relays and respective connectors and sure enough, both are in perfect condition once I removed all the old crusty dielectric grease! Took some time and lots of picking with solvent and fine point tool, but saved me from having to replace them unnecessarily! Thanks TBc forum!
