Looking for the nasty elec. drain!
Maltman
Ok....I finally got up the nerve and started looking for the culprit after I bought "another" battery and it went dead after two days..
well, I found the circuit that holds the key, but it happens to be the stupid courtesy lights, cig., chime, etc. circuit! I was geeked thinking that I would only sacrifice the cig. lighter and cure the drain....but NOOOOOO...it has to be more complicated than that!
So, I was hoping that someone on this board would have had similar problems in the past on the same circuit and might be able to help.
I know this is the culprit for sure since almost zero volts flow when the fuse is pulled....plug it in and we get nice size sparks every time I touch the terminal to the wire (battery and + cable)
Thanks,
Mark
