So I got this thing hooked up to my GN using a non-extender chip (Turbotweak 5.7) and a 1st gen LS1 MAF. I just started putting and cruising around and watched Integrator and BLM's on Turbolink. I know, I said Turbolink. It's all I have now.
Anyway, Integrator was around 138 around 1800RPM's and up to 158 around 3300 or so under light to mid throttle. Static cruising and idle was almost dead on 128.
So far I scaled mid load fuel so it is up to about 20% or so by 2200 and climbs a little as you go up the RPM's and it is closer, like 129 to 138-143. BLM's sit at 132 in the high cells. I also scaled the low load tune to a lesser extent and it is really close.
That being said, how close is good enough? It seems like I'm adding a lot of fuel. Is this normal?
I did do a couple 3rd gear WOT runs with it. 02 (NB) are at 785ish. I got a few knock counts at the high end, so I slowly scaled yp to 10% fuel in the High load tune. Ran again and no knock.
Hopefully tomorrow I can get my WB02 guage working and will fine tune WOT with that.
