looking to buy razers kit
ponykiller
i'm going to buy razer's alky kit and i was wanting to put a gauge to monitor the alky pressure, any one out there know type of gauge they are using? elec or machancal? my boost gauge is a single pillar machancal PHANTOM autometer, i like to go 2 gauges and put the red LED on with a dual gauge piller. any ideas or hints on this? thanks :confused:
if you want to read alky line pressure youll need more than your std fuel pressure gauge since you may see upwards of 250psi so forget about any cheap 100psi electic senders or efi fuel gauges , be prepared to spend some $$, and youll need parts that compatable with methanol full time , big $$$$
for a temporary check you can hook up a 300psi gauge on a hose and mount by windsheild , but only temporary for the test , dont leave it connected for long .
best advice is forget the idea of having a pressure gauge its just another distraction and potential for a failure
, besides razors kit has a visual indicator (led) as part of the kit that comfirms pump is on and that line has pressure once it gets above approx 30psi.
that helps i did not know the pressure was that high, wow. i think i'll stick to the boost and one unknown gauage. i'll pick something else.
