My shifter T-Handle became quite loose, works ok but I'm careful to not put much tension on it when changing to D, R, etc.  I seem remember a '69 A-body long ago had similiar shifter with a small pin holding handle onto lever, do the GN's have a pin up under that plastic cover?  If so, just replace the pin, or how do I fix it?
Another small but irritating problem: I think something came loose with the E-brake pedal. Although all works well, when the release is pulled & pedal pops up, it seems to come up more than normal & the BRAKE light lights up, but of course the brakes are not engaged. I can push the foot control down a little & click it into place & the light will go out (careful not to push too much & engage brake). It seems there must be a stop of some sort (rubber?) between the footbrake stem & hardware under the dash; I've taped a rubber stopper there but does not work satisfactorily. Think I'm missing an easy fix.
Anyone know answers these two non-performance but irritating problems? Thanks.
