Spoolfool's Christmas time contest.
SPOOLFOOL2
Fiberglass bumper filler dude. (949) 433-1257
Staff member
It's that time again. Going to keep this one simple. Just a fun contest that the winner will be picked New years eve.
Best response wins one of my Drip-Lip, oil catch thingies. I call it my stupid idea that works. Also, wanted to thank everyone for all the support for all the crazy stuff I've come up with. I'm happy to say that I'm currently working on some new stuff. Please check out my new-ish website for products and product videos. www.spoolfoolproductions.com
Contest is: Best story of carnage to an engine. It can be minor or catastrophic. More emphasis will be put on entertainment value. Bonus points for pictures.
Big thanks to Shane and all those who have supported this great site over decades. I truly believe that these cars would not be half the legends they are without this place.
Merry Christmas from the boys at Spoolfool Productions.
This should be good.
Mike Barnard
So Western Moderator
Carnage! I have a carnage story.
Not a buick, though you didn't specify. It was a turbo V6 though.
1994 Ford Probe. I ran this car from 2019 until I sold it in 2024. The engine had almost 300,000 miles on it, so naturally I threw an Ebay kit at it and doubled its output. At the 2021 Pine Mountain Hillclimb, I accidentally did not re-enable the rev limiter. I crossed the finish line at over 8200 RPM. Cracked the ring lands and bent three rods.
But that's not the carnage. The carnage is two weeks later. I didn't have time to rebuild the original engine, so I got a junkyard one. It was advertised as having come out of a Probe, but foreshadowing.
At the 2021 Time Trials nationals, I'm cresting the hill known as Tabletop between turns 14 and 15 on my first practice session on Thursday and I hear stuff bouncing off the floor, then the smoke, then the fire starts. I crest the hill at 16 and get the car over to the side and bail out. It's very on fire. Big fire. Looking around, I do not see the safety people coming and the corner workers are not leaving their stations. So I go BACK into the car, get the fire bottle, and proceed to put the fire out myself.
Back in the pits after helping the safety crew pick up the fragments of engine block and letting it cool off we get looking, and the car has multiple holes in the block. You can see straight through it between the first and second set of cylinders.
The block was split top to bottom. It was held together by the heads and the oil pan.
When I tore it down, the damage was epic.
Three rods broke. Three pistons also broken. One of the pistons was rotated 90 degrees in the the bore. The EXHAUST valves on #3 were bent from piston contact.
The root cause? The engine wasn't a Probe engine, which would have had a forged crankshaft. It was from a 1999 Mazda 626 or Millenia, and had a cast crank. The crank bent under load (I found witness marks on the main caps). The Mazda V6 block is extremely rigid, so when that crank got out of shape the block shattered at 7200 rpm along with several rods breaking. Everything cascaded from there. The oil poured onto the exhaust and ignited. A friend that was behind me when it happened said the fireball that came out from under the car was movie-quality. Putting the fire out myself saved the car. We trailered it home, grabbed the Buick and went back down and still ran the rest of the event.
I ended up rebuilding the original engine with all forged guts and ran it without major issues for three more years.
And I don't need to win, I already have a drip lip! But good opportunity to tell a fun story.
Merry Christmas !
This all engines or just LC2's?
I haven't had the pleasure of blowing up one of the two LC2's I've owned and driven and giving me a reason to build a more powerful one but I have destroyed a BBC once.
After many years of spraying my 396 (matching numbers btw) then a 454 I decided to upgrade the 454 with higher compression, larger cam, some 074 factory heads and a dominator carb. I never ran without an air cleaner before so I covered the carb with the carb cap after the swap while I wasn't driving it. Well the first time we went to the track I went to start it and pull it off the trailer. It wouldn't start, you see where this is going right? It never would not start up instantly. So I kept trying and when I put the throttle to the floor and continued cranking it started. All I remember ( 30 years ago) was looking down at my tach and seeing the needle around 12 o'clock which is 8500rpm. Then it just stopped, cranking it made a some horrible sounds so I got out to investigate. Pulled the hood and saw my carb cap sideways on top of the carb jamming the throttle wide open. I pulled the carb and saw chunks of aluminum everywhere. I also found out my MSD 7al 7400 rpm chip didn't work. Threw the carb and hood back on and went and had a few beers and watched some racing. Live and learn.
Damn another rev limiter. PSA on rev limiters here.
Nice products Mike.. you make anything for syty? Cladding, intake crossover etc..?
So no before and after pics of the ex
Nothing for them yet. I've had so much on my plate that it's rare that I can get caught up. I know that you guys want body kits. Just not sure that there is enough of a market for them at the price I'd have to charge to break even. I do love those things. It was great to have some at BG this year.
Completely understand where your coming from.. at the end of the day its the cladding that makes those trucks.. if/when it all dries up you can bet people will pay the price.. but ya weird market not even sure how many have survived at this point out of the original 7700 I'd guess 1500 to 2500 ?? Back to your contest I handed Richard Clark a basket case motor 20 years ago to rebuild but aint gonna bore ya with the details haha
Wheel came apart on the freeway one morning. No warning except 3 fast squeeks, then the brake rotor is digging a groove on the inside of the wheel. I don't know how that wheel didn't exit stage right and tear all kinds of stuff up.
Physics. The wheels are gyroscopes. So unless you turn or hit a bump, the wheel is going to say upright and moving along with the car until it stops spinning and either falls over or gets stuck under the car.
Glad your hear telling the tale bad things coulda happened.. those wheels have wrong offset or something, studs to short? Going another direction or replacing the 1? Bet black mesh would look good on that car for the contrast.
Same (new) wheels, same (new) tires back on it.
I like the look. And Mustangs still don't know what just happened...
I'm sure I'll get some advice here, but the car looks good in my eyes... so quiet down.
And that was a seriously scary day... Seriously.
A bump was what caused it to let loose, as far as I can tell. Three fast squeeks and then boom, it let loose.
The first pic in post 12 is a pic of when she came to a stop on the side of the road, Rotor cutting a new groove on the inside of the wheel. DEEP. you can see the hub sitting inside the wheel.
It was the first and only time the car left me sitting, to date.
The place I was at on that freeway, in a one lane "luge" lane, for lack of a better term, I was in an HOV lane transitioning from one freeway to another. One lane, a half car wide median on each side and 4 foot concrete walls on both sides. The HOV for SR51 South onto I-10 East, if you know that section of road, you know there is absolutely no where to go to get out of the way of traffic, and if things come off the car, who knows where they will go. Along the wall? Up and over the wall down 50 feet onto I-10 westbound, then through someone's windshield? Could have been SO much worse.
I got over right as much as I could with no steering available. Thank goodness a Highway Patrol roadside assistance truck came along, parked behind me with lights on, and waited with me until the Triple A tow truck came to get me. Triple A is a VERY good investment, for anyone! I highly suggest those of you who don't have it, get it. Cheap insurance against roadside problems.
That wheel stayed on the car even as the tow driver pulled it up on the truck, and again when he dropped it in my garage. I jacked it up, yanked the wheel, found no damage to the rotor, though I did replace it, bought new front wheels and tires, installed everything and VERY timidly took her for a ride.
All seems well a little more than a year later.
Still a pretty scary ride, I must say.
We are still in litigation with Weld, but that's another story for another time.
Give Guy the diaper!
That's a wild ride. I've always thought of Weld Wheel as a company with quality products. Guy. Did you buy them new? Wonder if they had any past history of getting bounced off a curb or something before you got them.
Good luck with that. They sold me wheels that weren't round once upon a time. Don't know if it was a manufacturing problem or they got beat up in shipping. They wouldn't replace, they had me ship them back and they beat them to within their "acceptable spec" for runout, polished them up, and sent them back. I ended up scrapping them. Most expensive trip to the recycler ever.
