Well i went out to the track Fri and i was quite disapointed
Im starting to slip into my go with another motor idea again . The Mph was 106-108 from 111-113 . These are the changes from sig , ATR front mount from stck big neck, 275/60/15 from 275/50/15 , and 9-11 conv 3000 stall from 12inch 2400 nonlockup .It was cold around 45 from 80 s with a slight head wind from no wind at all . and full 225/60/15s fronts instead of drag skinny fronts . The 60 ft time did get a little better , with my 009injectors @25psi on C-16 i had the F.P up to 55psi Vac. off to keep the O2s from going into the mid 700s and seeing 1-2deg of knock when the F.P was @ 43psi , Looking back at the previous 113mph the O2s were 800mv. in 85 degree weather with the stock big neck . The chip is a Reds street chip with 21deg timming.Is this enough to knock 5mph off my previous times ?? I think its possible but ??? Maybe the motors getting tired i dont know its an all stock Longblock w/ about 100k valve spring included . Last summer i ran 12.49@113 . Well i guess going slow is better than blowing it up . 12.80s @ 107 were average with a 1.90 60ft average well at least i beat a 68-70s chevelle w/ slicks once on my first pass and once again on my last pass . My next move is S-10 rear cyl &soft shoes , slicks and pinion adj . I guess my 60 getting better with 5660s springs ., blistens , swaybar and full tires is good considering their not really "Drag Friendly" My G.F " Doe Eyes ( on this board) was there for moral support , no passes yet . The coolest run all day was a silver stock looking Z06 went high 9s on juice, that was
