Jan Larsson
- Nov 22, 2001
So got some time today to look at the Lotek 2 Gauge Pillar pod for my TTA.
First the fit is pretty crap over all, the pillar pod is designed to fit ontop of the OEM pillar and be secured with 2 screws.
I started with positioning it as good as possible and drilling the 2 holes for the screws and then secured it in this position with the screws, you can see pictures (click link and then click on the thumbnails) and you can see how it fits ontop of the OEM pillar.
To secure it better I drilled a couple of small holes and used black aluminium rivets to hold it in place in a few strategic places making sure I got it to fit as good as possible on the OEM pillar. This way I got it to fit a bit better.
The worst area is the bottom as it's a bit shorter than the stock pillar and also at the top at the t-top, again see picture link, as nothing really matched at the t-top and it also made the t-top be a squeeze fitting it I decided to remove the part of the Lotek pillar in that area per my pictures.
After all this it fits and looks ok when installed in the car, no pictures of this yet as I still have to do some wiring so I'll post some more pictures once I got it installed in the car.
Overall taking the cost of the Lotek pillar I can live with it but I wish it would have been a direct bolt in with out all the hazzle to make it look decent ...
Anyway, hope this helps if someone else is going the Lotek route ...
http://www.tta1078.com/pillarpod/
