Lots of parts for sale, performance, stock
BLACK MAGIC RACING
formerly turbo_canuck
86/87 parts:
-Stock heater core- $50
-turbo heat shield (2) - $20 each
-Stock accessory bracket- $75
-Stock throttle cable bracket- $35
-stock rocker shaft assemblies- $40 pair
-stock intercooler shroud - $20
-pair of stock 8445 heads - $150
-2 driver side intercooler bracket- $25
-3 passenger side intercooler brackets - $30 each
-passenger side intercooler bracket cut for stretch intercooler - $20
-stock maf sensor - $ 150
-clear parking lenses - $15
-stock turbo (core) $70
-stock front sway bar - $40
-stock coil pack/module mounting plate - $30
-2 stock turbo cranks - $250 each
-Chrome tail lights - $60 each
-Blower motor- $40
-Flexplate - $35
-Stock Throttle body no arm, spring or iac- $ 35
-Stock plenum,$ 30
-stock passenger side header- $60
-passenger side taillight lens only - $45
-rear defrost window- $75
PERFORMANCE PARTS:
-2 weld pro-stars- 15x12, 7.5" backspace, 5x4.75 bolt pattern - $275 pair
-4"long 3"i.d. hose-blue- $15
-4"long 3"i.d. hose- black $15
- NEW chrome ds breather/ oil fill tube - $ 35
-2.5" to 3" reducer hose-blue- $20
-orange stripe street brawler converter - $275
-Stock pressure adjustable actuator- ta turbos $40 each
-Lokar trans mount dipstick + tube- $50
-Weber Billett solid roller cam,(cam only) 218-212, 511,503 lift. 113 lsa.- $200
-3.5" stub downpipe, 4" long, build your own DP, internal gate. - $185
-Wiseco forged pistons for 4.1, clearanced for stroker- $200 !
-Extended 14 bolt oil pan, deepened 1", $75
-FAST Jumper harness w/ wbo2, 3bar map harnesses- $ 300
-ATR external wastegate- $125
-Pair of stage 2 valve covers - $65
84/85 PARTS:
-engine accessory bracket - $25
-braided down pipe - $20
-4 '84 t-type wheels - $ 200
- '83 regal header panel - $175
Prices do not include shipping, and because of my job, i can only ship once a week. thanks!:)
Wiseco Pistons
May be interested in the 4.1 Wiseco pistons. Can you provide pictures and detailed information about the pistons? Thanks
Stock Intercooler Shroud & Turbo Shield
What Condition Is The Stock Intercooler Shroud And Does It Come With The Plastic Grille At The Bottom Of The Shroud? Is The Turbo Shield Stock Or Is It Cut For Downpipe? Can You Send Pictures!
Thanks Vince
the intercooler shroud is worth the $20, not the best condition, but better than none. lol.. I have 2 shields, both uncut. Thanx!!!
