Lots of Parts
Tie-down Pending
Manual Boost Controller Pending
Mike
Timing set SOLD
GNX bushings SOLD
HD PTE wastegate SOLD
Mike
Chrome Rear Cover SOLD
Manual Boost Controller SOLD
Mike
Chips and injectors were sold on ebay due to lack of interest here.
Mike
Updated:
Parts for 86-87 Buick GN:
5. Stock cross-over pipe in excellent condition.
7. Stock intake flexible air tube.
8. Stock (Kirbans) oil cooler lines.
9. Stock fuel line (frame connection to FPR).
10. New brake line (curly one, goes from master cylinder to proportion valve)
11. Steel braided line, attaches to fuel rail then to fuel pressure gauge (Qty, 2)
12. Rail fuel pressure gauge (direct bolt-on)
13. Factory vacuum block (fits onto to top of plenum).
14. 120 amp A/C Delco alternator.
17. Turbo oil line (goes from top of turbo to oil fitting in block, Kirban replacement part.
18. Comp cams 853-12 hyd. Roller lifters, have 5, I tossed out the 6th one as it made a noise, the 5 I have work perfectly.
19. IAC factory housing w/bolts.
20. GM new motor mount, labeled as RH, part# 1258718.
24. Hotchkis passenger side forward A-arm heat shield.
25. Engine tie-down (ratchet type).
26. Silicon hoses for intercooler connections, I have a blue set and a black set. The blue set has two 2.5”x2.5”, one 2”x2” and one 3”x3”. The black set has two 2.5”x3”: 3”L and one 2.5”x3”: 4”L.
27. Rubber tube for Big-Mouth intake system with air temp sensor, size is 3” one side and 4” other side.
28. Valve cover breather, 2 Moroso and 2 Kenne Bell, push-in. I have 3 rubber inserts and 2 insertion sleeves ( for aftermarket valve covers). Also have the small breather that is made to fit the stock valve cover between turbo and valve cover.
31. Canton radiator overflow tank w/mounting clamp, size is 6”L and 2.75” diameter.
32. New fiberglass bumper filler, driver’s side rear.
Mike
