lots of parts
projectmoneypit
tx firefighter
still cleaning out garage to work on other projects. Prices are plus shipping except for the first 3 items they are shipped pricing. Pics on request call greg 817 202 7258. First to pay gets part, tired of people saying they are going to buy then never do.
the following have pics in the ad
all 4 door escutcheons, the 2 front are the lighter grey and the 2 rears are dark grey (dont know why) $40 each shipped the front one in the pic shows a little chrome peeling at the pull strap mounting point and the pull strap mounting flange cracked/broken. All mounting tabs are great with the nuts.
upper door panels no rips slight fading on top has a couple of spots of a tar like substance which can be cleaned off with goo b gone, i just got tired of messing with it. $100 pair shipped.
lower door panels with concert sound speaker covers no cracks or breaks $100 shipped or all 4 uppers and lowers 150 shipped
pics on request for the following
INTERIOR
#5 HVAC VENT BOX MOUNTS TO BULKHEAD BEHIND DASH $20 O/H 2 SHOP ATTIC
#7 LEFT REAR LOWER SAIL PANEL GREY/BLACK $15 SHOP ATTIC
#8 LEFT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC
#9 RIGHT UPPER REAR SAIL PANEL GREY/BLACK $10 SHOP ATTIC
#10 RIGHT LOWER REAR SAIL PANEL GRE/BLACK $15 SHOP ATTIC
#13 REAR METAL HEADLINER TRIM $10 O/H 2 SHOP ATTIC
#26 POWERMASTER BRAKE PEDAL ASSY $30 O/H 2 BOX 1
#27 DASH CHROME STRIP $25 BOX 3
#29 DASH HARNESS RADIO PLUG CUT 1 SPLICE $150 BOX 1
#37 LOWER DOOR PANEL SEALS $10 PR BOX 1
#47 PASSENGER UNDER DASH COVER $10 O/H 2 BOX 1/2
#48 SEAT BELT TENSIONERS 2 PAIR O/H $10 EA BOX 2
#49 DOOR JAM VENT $10 BOX 2
#50 DRIVERS SEATBELT GUIDE GREY $10 BOX 2
#51 REAR TTOP HEADLINER TRIM GREY $30 BOX 2
#53 PASSENGER KICK PANEL 3 PIECES GREY $30 BOX 2
#54 DASH CLUSTER DASH PAD GREY $30 BOX 2
#55 VACUUM BRAKE PEDAL ASSY $30 BOX 4
#56 RADIO BEZEL NICE NO BROKEN TABS $15 BOX 2
#58 PASSENGER LOWER PIVOT SIDE SEAT TRIM GREY $10 BOX 2
#59 TTYPE HORN PAD WITH HORN PLATE BURGANDY $10 BOX 2
#61 INSTRUMENT CLUSTER MOUNTING BRACKET $50 BOX 3
#62 GRAND NATIONAL FLOOR MATS (4) BURGANDY $100 SHOP ATTIC
#63 REAR VIEW MIRROR $5 BOX 2
#68 BURGANDY SUN VISORS NO MIRRORS, REDONE $50 PR BOX 3
#69 BURGANDY REAR STEERING WHEEL COVER $10 BOX 3
#70 GLOVE BOX INSERT $10 BOX 3
#71 HVAC CONTROL HEAD COMPLETE MANUAL $40 BOX 3
#72 HVAC CONTROL HEAD FAN SWITCH KNOB BROKEN $20 BOX 3
#74 LARGE GREY TTOP CENTER TRIM NEEDS PAINT $25 BOX 3
#75 PASSENGER B PILLAR GREY FOR TTOP $15 BOX 3
#79 ANALOG INSTRUMENT TURBO CLUSTER $75 BOX 3
#89 HVAC BLEND DOOR CABLE $10 BOX 2
#90 GLOVE BOX LATCH/LIGHT SWITCH $5 BOX 2
ENGINE COMPARTMENT
PART DESCRIPTION PRICE PART LOCATION
#1 86-87 INNERCOOLER $60 SHOP ATTIC
#2 84-87 RADIATOR CORE SUPPORT $75 SHOP ATTIC
#11 MAIN HVAC HOUSING ASSY FOR BULKHEAD $75 SHOP ATTIC
#25 HVAC BOX ENGINE COMPARTMENT SCREEN $30 BOX 3
#30 INNERCOOLER FAN $15 BOX 1
#31 A/C CONDENSOR $20 SHOP ATTIC
#32 HEADER PANEL TOP BRACE $15 O/H 2 BOX 1
#33 TRANSMISSION INSPECTIO0N COVER $15 BOX 4
#34 BLOWER MOTOR WHEEL $5 O/H 3 BOX 1
#35 ENGINE OIL COOLER ADAPTER AND HOSES $40 BOX 1
#36 HOOD HINGES O/H 2 PR $15 PR BOX 1
#38 84-85 HOOD TURBO HEAT SHIELD $10 O/H 2 BOX 1
#39 A/C DRYER $10 BOX 1
#45 POWERMASTER COMPLETE INOP MOTOR CLICKS $80 BOX 4
#60 THROTTLE CABLE $20 BOX 2
#64 COOLANT OVERFLOW BOTTLE WITH CAP $10 BOX 2
#65 CRUISE CONTROL CABLE $10 BOX 2
#66 CRUISE CABLE SERVO BRACKET $10 BOX 2
#67 HOOD RELEASE CABLE $10 BOX 2
#82 UPPER SPEEDO CABLE $10 BOX 2
#85 HOTAIR TURBO HVAC BOX HEAT SHIELD $20 BOX 4
#86 WASHER BOTTLE WITH CAP $10 BOX 2
#88 DRIVERS INNER FENDER WELL TIRE RUB HOLE $20 SHOP ATTIC
#91 FRONT RAD SUPPORT CROSS BRACE 2PCS $10 BOX4
#41 WIPER ARM ASSY $20 BOX 4
BODY
#3/4 REAR WINDOW W/WO/DEF $40 SHOP ATTIC
#6 REAR WINDOW OUTER TRIM 3 PC $30 SHOP ATTIC
#12 DRIVER DOOR WINDOW $40 SHOP ATTIC
#14 WINDSHIELD TRIM 3 PC $30 SHOP ATTIC
#15 HOOD TRIM NO DINGS NEEDS PAINT $25 SHOP ATTIC
#16 RF WHEEL WELL TRIM NEEDS PAINT BLACK $40 SHOP ATTIC
#17 RR " " $40 SHOP ATTIC
#18 LF " " DENT DING PAINT $10 SHOP ATTIC
#19 LR " " $15 SHOP ATTIC
#20 LR " " $10 SHOP ATTIC
#21 RR " " $10 SHOP ATTIC
#23 84-86 GRILLE MELTED DRIVERS TOP NO BREAKS $30 SHOP ATTIC
#40 TRUNK LATCH NON ELECTRIC $7 BOX 1
#42 GAS TANK STRAPS $25 BOX 4
#43 PASS QUARTER WINDOW CHROME TRIM NICE $20 BOX 1
#44 DRIVERS BLACK WIPER ARM GOOD SHAPE $10 BOX 1
#46 TAILLIGHT FILLER NO LICS PLATE LIGHT $15 BOX 1
#57 DRIVERS QUARTER EXT HOLES FOR SPOILER $15 BOX 2
#73 PAIR OF QUARTER WINDOW W/1 SEAL NO TRIM $40 BOX 3
#78 PAIR QUARTER EXT NO SPOILER HOLES $30 BOX 2
WIRING
# 76 CRUISE CONTROL HARNESS AND VAC HOSE $25 BOX 2
#77 TAILLIGHT HARNESS FROM DASH TO TRUNK $30 BOX 2
#80 TAILLIGHT FUEL PUMP HARNESS F/P WIRES CUT $30 BOX 2
#81 REAR WINDOW DEFROST WIRING HARNESS $10 BOX 2
#83 PASS DOOR WIRING HARNESS PW PL CONCERT $25 BOX 2
#84 DRIVER " " $30 BOX 2
MISC
#24 51.5 INCH 200R4 GN DRIVESHAFT $75 SHOP ATTIC
#28 USED STOCK REAR COIL SPRINGS $25 PR BOX 1
I'll take #27 pending picture.THANKS
Kinda hard to tell in pic but there is about 1/8 to 1/4 inch of peeling on the end otherwise there is just a few of the verticle lines in the chrome as seen in pic.
