Lots of stuff for sale and trade...Will ship anything
For GNVAIR...You can see the scratches on the end and around the rubber strip but nothing that wont get taken car of when they get painted
Yeah thats fine. I just need a solid core for when I repaint the car. I have powder coated bumpers at the moment and am not very happy with them. PM your number so I can make arrangements to come out there. Thanks!
What dont you like about them
They were chromed bumpers that someone powder coated and they are no where near as smooth as bumpers that were primed, block sanded and painted.
I want the front and rear bumpers if they are not sold yet. How much to ship to 39212 ?
The rear bumper pictured is sold to GNVAIR but the front is still available and I have another rear bumper available but it does have a dent in the center. I can get a picture this weekend if your interested. Also are you looking to get only the bumpers or do you also need the cores. Without them will save a ton in shipping.
Im getting close to getting my car running so time to get rid of the stuff I dont need anymore. I will trade for performance parts, gauges, cool parts...Stuff like that. If the prices arent good enough let me know some say Im easy going. Shipping is additional.
Frame-$450...This frame was the one under my car before the frame swap. It has two body bushing holes that are starting to rust but nothing really bad. I also have front suspenion I can include if that would be better for you.
SOLD Dash wiring harness -$150...I have two of these, they are both out of GN's and arent cut up and hacked. Really good looking harnesses.SOLD
Fuel lines-Offer...These are both fuel lines that go from gas tank to front of car. Dont know what their worth. Shipping will be expensive because of how long they are.
Brake lines-Offer...Again this is the line that goes from the metering block up front all the way to the rear.
Heater/AC controls-$20...I have two of these and both in really good condition with all wires and lines out the back
Tilt Sterring column-$85...This column came out of an 84 I parted out and comes with key , tilts, and also a column guard. It is a column shift but the shifter has been removed from it.
Trimmed fenders, wheel wells, and core support-Offer... Thses came with a car I bought and was never told about. The wheel lip was trimmed because the PO had a lowered car and I guess didnt want to take the time and do it right. otherwise they are beautiful fenders. The core support would be good for someone running a huge custom front mount because the headlight holes are cut open. If your interested let me know because otherwise their getting scraped.
Motor mounts-$70...These are new and have been sitting on a shelf for a long time. Bolted in once then removed for H and R's
SOLDIntercooler-$50...Stock intercooler looks really good. couple bent fins but nothing serious.SOLD
Intercooler Brackets-$40...For the interooler, both of them together.
SOLD Oem master cylinder-$50...This is still in the box and unused. Obviously its for vacuum brakes.SOLD
SOLD Kirban engine gasket set-$25...opened it up and it didnt even have the gasket I needed.SOLD
2 exhaust gaskets-$10
Upper Speedometer cable -$20
Intercooler fan-$20
SOLD Up pipe-$10...Looks like it was on a car that had an oil line let loose because its covered in something that doesnt clean off. Would be good core to send to powder coater or have BOV attached to.SOLD
Crank pulley-$20
Used Radiator hoses-$5 for both
Water pump pulley-$50
SOLD Trans cooler lines-$30 SOLD
Turbo to pass valve cove tube-$Offer
Front suspension-$90...Includes all brake components, control arms, spindles, springs, tie rods, steering parts. Pretty much eveything except the pitman arm and shocks.
Crossmember-$40
Power steering hoses-$20...both
Sway bar-$40...Front
Gn bumpers-$75 each...Both are really nice and rust free. They need to be painted but other then that few light scratches...Will trade for fiberglass or a nice chrome front bumper. Rear sold, have another front and rear still left
Heating duct-$65...These are the ducts that are in the dash, I got them when I bought a bunch of parts.
SOLD Flex plate bolts-$25...ARP and still in the boxSOLD
Flex plate-$20
Condenser-$30...Has some bent fins but their in the corner so air flows isnt effected.
PENDING Stock intake box-20 PENDING
Cam sensor cap-Pay shipping..This was a giant headache. One wire pulled out from plug. If you fix the wire you have a perfectly working cam sensor.
SOLD Oil filter gasket-5 each...These are the gaskets that go between the block and oil filter adapter. I ordered these from the dealership and could only get a five pack then it turns out I needed something else.SOLD
SOLD Cam sensor tool- I bought this from a fellow member a while back and it works great. The case is a little warped but It still works great. Whoever buys this I will guarentee it works.SOLD
Door hinges-$40...This is all four hinges and their really tight and good. I rebuilt my hinges and then these came with some doors I bought.
Cluster support-$20...This is the piece that goes behind the gauge cluster. The top two tabs are broken but I just used washers and it worked great with no rattels.
Broken steering column-Make Offer...Genius previous owner tried to "fix" it, needless to say, I got the car with bearings all over the carpet.
Down pipe-$35...Stock
I'll take the crossmember if from a turbo car and the cam sensor cap with messed up wire have two that have good plugs but the plastic tops are cracked maybe i can make one good one.
Are the radiator hoses still available? Are they in good condition?
Yes they are still available and their good driver hoses, maybe some cleaning but no holes, gashes, or anything like that
Ill double check on the crossmember to make sure its out of a turbo car and as for the cap all it needs is either the plug fixed or a new plug.
I'll take the hoses. Shipping to 20854? If shipping is cheaper for one hose, I only need the upper.
oldsracer - I found an upper radiator hose last night from a local source. Thanks anyways. Good luck with the rest of your sales.
Good timing Haha
Interested in the front lower a-arms and spindles if you are willing to separate. Send me a conversion with price with shipping to 03064. Thanks.
