Wondering if anyone can help me figure out why I get KR (up to about 4 degrees) on only about 10# boost. Basically a stock setup. This KR problem has plagued me from day 1. With boost limited to 10#, it's an intermittent problem. Going WOT from freeway speed I get blips on the knock guage at least half the time, actual KR readings on the SM about 40% of the time and sometimes get no KR (about 1/2 the time). I usually let up. Once it went from .9, 1.x, 3.x,back to zero. My o2 are 800's - 830's generally at WOT. My LM-1 however is reading pretty rich - generally AFR less than 10.5, at times dipping into the 9's.
SM numbers at idle:
AF 6
L8 50
bat 14.1
Int 128
BL 118
Clt 157
ATS 68
RPM 650
TPS 0.44
IAC 34
CC - cycles appropriately
MAL - 0
Some things I've tried and some observations:
This seems to be occuring independant of my octane - I recently ran full 100 octane Torco fuel, now a mix of that 100 + 91 octane; still knocked on 100 octane.
No difference with my stock OEM MAF and a T+ and LS1 MAF combo
Checked my coil with ohm meter - all readings between 11-12K
Fuel pressure rises at least 1 lb for every lb of boost.
Tried both a TT 5.6 (for stock injectors), stock chip and another chip for stock injectors
Tried 2 different ECM's
Fixed all exhaust leaks as far as I can tell. No header leaks at all
Fixed all vacuum leaks.
I think my motor mounts are stock but look great and engine doesn't rock much
Dp not hitting frame etc.
Knock sensor checked and torqued to only 14 ft/lb
New plugs/wires
Injectors cleaned
Car drives fine, has steady vacuum readings, and passes Ca smog easily.
Any thoughts would be greatly appreciated. Especially things to check or try, and an explaination on how Im getting knock yet my O2's are fine and my AFR on my WB are actually pretty low.
Thanks.
SM numbers at idle:
AF 6
L8 50
bat 14.1
Int 128
BL 118
Clt 157
ATS 68
RPM 650
TPS 0.44
IAC 34
MAL - 0
New plugs/wires
Injectors cleaned
Thanks.
