Low boost problem?
finialy got to open the buick up, and I was wondering, my boost is supposed to be around 11-12psi correct?
Im only boosting 7-8psi, What is the stock boost level for the hotairs?
Also, Im going to up it to around 13-15psi of boost. Do you think I can do this with no problem?
It had a Kenne Bell Chip in it, And I was wondering. Can a chip give you more boost?
If so then that could be why the chip was making it run richer.
They gy said it was set at around 15psi before I got it, what should I do?
- Cody
- 84 GN
Do you know you have posted this thread twice in the Hot Air Section:confused: I replied to the other.
I had the exact same situation as Bryan C. My CAT became plugged up and eventually the car would not boost at all. I now keep my new CAT in the trunk. Brad
