I have a low boost problem on a TTA. Only 9psi. New car to me. No history from owner.
1) Engine runs great with good oil pressure. How do I tell if it is the turbo? I found the plug off the controller and the other lines on the controller are are ok.
2) I have bad exhaust leaks that are in the process of repair now. Manifolds are ok.
3) Would you replace all tubes intake and intercooler first? They are factory but looked good with no visible splits.
4) Wastegate sticking?
5)
5)
