Low Fuel Light not turning off.
Antbankstwo3
I was putting my dash cluster back in - I noticed the bulb & the housing it sits in was missing in the slot for the Low Fuel Light. So I put in another when I put the dash back in. Then I quickly noticed that it DID NOT shut off. That's probably why the previous owner took it out.
Any ideas why it doing that & is it an easy fix. I don't really need the Low Fuel Light, but would be nice to know how to fix it if I want to one day.
Thanks in advance!
our cars didnt have low fuel light
the riviera did and the clusters are similar and it didnt use a bulb but rather a module with a bulb on it
if you wanted to you could get a low fuel module from a riviera and twist it into the hole behind the low fuel indicator
Does your car have an ALKY kit on it?
i would guess no because he stated he put a bulb in where the module goes and that hole is not for a bulb as the terminals are the fuel level voltage for the module . putting a bulb there it will remain on and may vary intensity with fuel level
The low fuel light isn't just a bulb... it is a module with some resistors as shown in the pics.
May explain why it is always on...
Low Fuel Level Module
GM # 6432974
Low Fuel circuit board from a Buick Riviera-
Also an option on the high end Buicks like Riviera and Park Avenue
http://www.turbobuick.com/forums/threads/low-fuel-light-on-all-the-time.208378/#post-1493960
http://www.turbobuick.com/forums/threads/low-fuel-module.260590/
http://www.turbobuick.com/forums/threads/twilight-sentinel.21417/#post-136378
Oh! So that explains it! I didn't know that! Thank you Pacecarta!
Bescurred - No Alky
GM # 6432974
Thanks for all the info. It's good to know. I'm not too worried about it at time time. Just thought there was something wrong. I appreciate the input.
