Chatmanboy
- Jun 25, 2009
Need some assistance because I did all that I can think of!
When I start the car Volts on scanmaster, and alt and battery reads around 14.2v. After letting the car run for a few minutes volts changes drastically and volts indicator starts to flicker on and off. Then only one headlight would work, loss of power, and volts would constantly jump around and volts read as low as 11v.
Alt and Battery are new. Check/cleaned all grounds (I Think), Checked the battery cables, checked the starter wires, replaced the ignition starter switch. Everything that I check seem right but problem is still there.
Is there a thread on all ground locations, may have miss some? Could a coil module cause this?
