Hey guy, just a quick question for ya. My right front control arm bolt has fused together with the bushing and I cant get it out. I have heated it up and everything. When I turn the bolt, the rubber inside the bushing turns as well. I tried to cut the bolt with a sawzall but it just eats the blades and doesnt cut the bolt. Now my question is, can I cut the bushings out between the control arm? Or is the control arm sleeved for the bushing?? It loks to me by the new bushings that they come with it's own sleeve. And the control arm looks to have flanges on each side. Have any of you popped your bushngs out? Is is safe to cut it or will I be cutting the control arm? By looking at the control arm that I got out already, it looks like i should be able to cut it. Just want to double check! Thanks! -----Jeremy
