Eric Stauch
Nasty87
- Jan 12, 2008
Hello everyone I have a few parts I know longer need. all parts are not including shipping and came off a 87 GN, Thanks! I will send pics upon request. I work full time and go to school so if it is a day or so before I get back to you dont freak out.
1. Stock lower intake (bare)- $100
2. Metal coolant line on side of intake- $20
3. Stock cam looks great no worn lobes will throw in stock springs- $30
4. Stock crank pulley powdercoated silver- $15
5. After market EGR valve known good also original EGR valve unknown if works but it holds vacuum along with two hold down brackets- $20 for all four items
6. Passenger side IC bracket powdercoated black- $15
7. Bracket that bolts to firewall then powermaster bolts to that- $15
8. Aftermarket stock radiator not 3yrs old- $70
9. Stock oil cooler lines- $15
10. EGR solenoid known good- $15
11. Purge solenoid, the one on the charcoal canister- $10
12. Crank sensor known good- $10 (with bracket)
13. Stock injectors- $40
14. New remanufactured AC Delco alternator never been used- $70
