SignUp Now!There was thread with a guy selling a bracket and bolts so that you could use zo6 brakes with a s 10 spindle and hub im not sure on the ls1 brakes but the the bracket seemed fairly simple im sure 1 could be made to adapt to the ls1 brakes also...I dont think its a straight bolt on someone would have figured that out by now either on here or on the s 10 forums but i guess you never know till you try..You are the first person ive heard to metion tryin it though...No-not the same, the S-10 already comes with a cut down hub that doesn't have to be modified and I believe the LS-1 rotors will slip right on to.Just don't know if the calipers will work with the modified bracket.
I am trying to find out if I can put the ls1 brakes & brackets on a s-10 spindle and if it's a direct bolt on using the ls1 caliper bracket-it was mentioned that someone did it with ZO6 brake calipers so I'm thinking it's a direct bolt on without having to cut the spindle and hub down like the stock parts-it would save alot of work plus I ve been putting together parts to do the ls1 swap.
