Originally posted by TurboTR A few quick ones, what is the GM PN for these coils? And how did you make the connection between the edist and the coils? What connectors?
eDIST comes with the connector for it's self.
I used the O2 sensor sonnectors off of a late Caprice, they are 4 pins in a row, but you have to cut the nib out so they plug in.
You have to use the GN ign module.
At low speed the GN ecm doesn't generate an EST signal, so you have to wire the coil wires together, and then use a 1K resistor to the point side of the resistor, and that will be where you pick up the EST signal.
