LS1 or LT1 cooling fans
Paul Lohr
Is anyone running the LS1 or LT1 cooling fans with the rear mount intercooler? I have an 1986 T-type that has a nearly worn out cooling fan motor. I like the idea of using the LS1 or LT1 fans because replacement fan motors are readily available at most parts stores, they probably cover about 70% of the radiator, and the reliability is known to be decent (from my limited time as a technician). I've seen the write up on the the Jeg's dual 12" cooling fan install.
Here is a link to the cooling fans. Who knows if these dimensions are correct, or if they include the brackets.
https://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=BK_8552344_0325567282&An=599001+102000+50012+2012008
Thank you for any help,
Paul Lohr
