Lucas 009 42.5 lb/hr Injectors and Thrasher 108 chip
Sal Lubrano
42.5 Lucas P/N 621031, green stripe, for sale 5k miles on them. $200 Shipped in USA
Thrasher 009's 108 Race chip. 10843-J2t.00 Sold to me by Scott Simpson $25 shipped in USA
http://www.thrashercharged.com/Chips_htm/GNttype.shtm
$210 for both shipped in USA prefer Check or money order, Will take paypal for additional 3% for cost of paypal fees. E-mail for pictures
Turbo1002@aol.com
Delphi / Lucas
42 lb / hr. '009' Disc Injectors
Part Number Delphi 01D030B (Lucas old 5208009, Lucas New 621031)
Static Flow Rate: 42.29 lb/hr @ 43.5PSI (300kPa) or 320gm/min
Dynamic Flow Rate: 9.96 gm/pulse - 2.5ms pulse width and 10ms repetition rate
Coil Resistance: 15.9 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Additional Information:
Top feed disc injectors use a small disc with six holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
