Lug Nuts
Hognose
Can I use my Lug Nuts from my GN wheels on my T-Type wheels? I am going to swap them and need to know if I need different lug nuts. Thanks
Matthew
are 1 set of wheels steel and 1 set aluminum? If so, dont use them. They will go on but it wont be right. Lug nuts for aluminum wheels have a lip that goes inside the wheel itself and stell wheel lug nuts are beveled and ride on the wheel.
I think WSformula was thinking of wheels like Weld that require a lugnut with a shank that is inserted into the wheel while drawing against the axle or rotor. On your wheels that are the cast Ttype wheels, the lugnuts are the same. You should have no problems here. Some one correct me if I am wrong.
Originally posted by machinegun
.......your wheels that are the cast T-type wheels, the lugnuts are the same. You should have no problems here. Some one correct me if I am wrong.
The lug nuts are different, but the same as far as the wheel is concerned!:)
The tapered flare on the alum lug nut is larger than the one for the steel wheel and it is a little longer. They should interchange w/o any problem.
