gn powered s-10
- Dec 10, 2003
ok guys is there a good machine shop close to baltimore( I live in elkridge md) that can do good machine work on the gn block and do a mild valve job
(3-angle valve job and mild p&p) as for the block i want to go .030 over and have it cleaned and new freeze plugs and cam bearings installed , and also have new rod bushings installed with new pistons and some ARP rod bolts put in too
thanks for the help
hopefully the s-10 will have a new turbo power plant soon
thanks to CRAZYGN he instigated it all
thanks for the help
