What does it cost to...
Mag? What exactly is that?
Sonic check? What exactly is the process?
Clean or vat??? Not sure what vat means
Hone cylinders?
Bore cylinders?
Bore cylinders with a torque plate?
Deck the block?
Deck the pan rail?
Align hone?
Align hone or bore with torque plates?
Install cam bearings?
Turn a crank?
Resize rods?
Press pins?
Install rings?
Balancing?
Install freeze plugs?
Drill out larger oil holes on #2 and #3 mains?
Check clearances and assemble a short block?
Assemble and install a blueprinted front timing cover?
Check cam play and adjust for thrust...or roller cam end play?
Some of my definitions are rough but I'm just taking a stab. I think this info would be very useful to someone getting their hands dirty for the first or second time. You know what they say....if you don't know how to work on a TR then you don't need to own one.
Please add to if I'm missing something. Seems like a lot of guys including myself rebuild an engine here or there. Would be nice to know some competitive prices to how much this stuff usually goes for. Maybe make it a Sticky? Thanks!
Hone cylinders?
Bore cylinders?
Deck the block?
Deck the pan rail?
Align hone?
Turn a crank?
Resize rods?
Press pins?
Install rings?
Balancing?
