Made escutcheon nut removal tool
Gunmetal87
Tried removing nuts on the escutcheon trim piece with the flat screw driver method and found it to work only on some of the nuts. I was afraid to use this method to screw the nuts back on to a new escutcheon because I couldn't get the nut to screw down evenly.
Thought about using a hex key and drilling a hole but don't have a drill press, so I modified my 1/4" bit screw driver. I just used a file and slowly work the six sides down to fit snug inside the fastener nut, following the inside hex pattern where 1/4" bits sit.
Now you can put even pressure on the nut while screwing it down onto the escutcheon.
Here's some pics
