OK, maybe these are already available somewhere but if so I haven't been able to find them. I think it would be nice to see some extra-long (so they can be cut to length) MAF pipes and cold air kit pipes with a 3/8" bung already welded in for the IAT sensor, or at least have the welded-in bung option offered. Maybe another option would be a short section of pipe for in between the MAF sensor and air filter with the bung welded in. I've been running a cone filter on my GN ever since I bought it with a hole punched into the collar and the IAT sensor shoved in it but in the back of my mind it's always seemed to be a sort of hokey way of getting the IAT sensor installed. I would like something that looks a little more professional and is sure to seal much better too. I'm going to be looking for a new MAF pipe or cold air kit soon (my current MAF pipe is way too short as it is and once I switch to an LT1 MAF/translator my filter will be even closer to the alternator pulley
, plus I'd like to get the air filter out from behind my radiator) so what do you vendors got for me?:biggrin:
