VtheGNMan
- May 19, 2014
I never liked the look of having the MAF Translator screwed the inner fender well or the plastic wheel wells.
Especially since you can get a nice translator cover plate with cool logos on them from our awesome vendors.
Built a bracket to hold it at the top radiator support height. All the wiring gets neatly tucked under the support with the headlight wiring.
Simple piece of 1/4 acrylic with a 90 bend to attach it to the inner fender. Used the existing bolt that also holds the horn inside the fender and an existing hole in the radiator support. Just spaced it down the correct height.
I left the bracket dusty so you can see where it mounted to it.
I can add a picture of the bracket removed later on when I have it all the way out.
