Assuming you're talking main bearing clearance, there is much discussion about this. I rebuilt my motor in the fall, and had a lot of back and forth with my machinist, who advocated loose, and my GN-colleague, who said tight.
Factory specs are believe it or not, 0.0003 to 0.0018.
I didn't want to cut my crank, so I gave it a light polish. Using that, and 1-under bearings (Clevite) my clearances came out to 2.0 to 2.2 thousandths.
While this is above factory spec, oil pressure is fine. The gauge read 37 psi at the end of the 20 minute cam break session (hot idle) with a standard oil pump.
