Woohoo!!!! MUCH better. I will go ahead and increase initial just a hair more since I still get a few counts if I really slam it, but it is dialed in much better. AFR is a solid 10.8:1 at the moment. I noticed that I'm somehow running 24 / 22 degrees of timing, so I need to pull that back to 21 / 19 and will lean it out to 11.0:1. I did get a little crazy and run it past 110 and I was starting to lean out. So now I need to either up the fueling past 5500, add a little more alky, or pull timing back to 17 above 5500. I'll play with that at the track.
