TURBOELKY
- Jun 27, 2005
I need to know how to run a lock up switch for the converter. The tranny is a 2004r, I swapped it out for my broken brf, but it only has 3 pins in the 4 pin connector. I've tried to do research on how to do this but no luck. The thing is the 4 pin connecter does not fit, so I need to know how to run a manual switch to lock the converter directly to the tranny. Can somebody please shed light on this, the tranny shifts really well without the lock up, but as I've read it will not gain proper cooling with out the converter locked up. I dont want to break this one. So if you can, yell at me on how to run a lock up switch directly from the transmission plug. Thanks
