Manual torque converter lock-up on THM-350C.....
Dont ground anything!!! just leave switch (3rd gear) out. Ypou will have to toggle any time. It is alot simpler than you are making it.
Bruce
WE4
:confused: I don't understand, what do you mean?
O.K. The red wire comes out from the case connector to the selonoid, (+). The other wire, black (-), coming out from the selonoid goes to the 3rd gear switch, (gov). So, I just cap it and not ground it at all? :confused:
Click on the link below and see my schematic...
http://members.telocity.com/~familiadiaz/TCC.jpg
Ok ground the black wire or negative side of the solenoid to a VB bolt. . Connect switched power to the red wire. That is it. Leave the gear switch alone.
Bruce
WE4
Thanks Greg!
Actually, this is my internal trainy wiring harness.....click the link.....
http://members.telocity.com/~familiadiaz/TCC2.jpg
The case connector has two wires coming out from it. The red wire, (+), and a white wire that attaches to the other side of the 3rd gear switch. This white wire comes out from the ECM. See link.
Since I am removing the fuse from the ECM, (I'm going to a non-electronic carb and a non-CCC HEI distributor system), I can pretty much leave the white wire attached to the 3rd gear switch.
I'm still not clear on the toggle thing. If it's toggled 'on' will it automatically lock at a certain speed and unlock at a another, (other than when I apply the brake). :confused:
350C trans into 46 ford pickup
I have a 350C trans & an early 80's buick engine, want to put it in a 46 ford
p/u, need to know how to wire the lockup converter,the electronic dist & carb
have been removed, replaced with a standard HEI dist and edelbrock carb.
The wires coming out of the left side of the tranny are, Tan with a Black stripe, Purple, Dark green with a black stripe, and a ground.Any info or diagrahm would be greatly appreciated.THANK YOU
Look at this page a click on Fig.40, looks like 12V to the purple wire should do it. Diagram is for a 83 Monte SS that came with the 350C trans.
AutoZone.com | Vehicle Selection - Year
Purple wire is the hot wire, looks like gets hot with key on. Now need to know what to do with the other two. Thanks for yhe diagrahm
