Originally posted by quickt
Scott can tell you first hand. I installed the TCI VB right out the box on 3 trannys. All 3 locked up on the 1-2 shift. I do mean screeching tires like you slammed on the brakes. The older trannys seem to flair on the 2-3. I have also installed that VB as is and it turned out ok a couple times. They are very pressure sensitive. Too much pressure and throws everything out of wack. Not enough and the tranny will be sloppy and kill clutches with the quickness. So I liked it so much I decided I would modify it so I could use it in other apps. If you have a good tranny I would try it as is. Just make sure that your first few shifts are on jack stands so you can see that 1-2 lockup if there is one with your tranny. Trust me you will never know till you check it out. I make mods to the Vb and the transmission to make it work the way I want it to so no way I could sell you one that you could bolt on your trans as is. When they are right they are slick.
