HELP ! - RollMaster Gold standard and Valve Spring Tool
Fikse7
Guys/Gals - I'm trying to tackle the timing chain and valve springs job over the Christmas/NewYear's break, but can't find either of these items in stock. Anyone help locating either?
Actually, no one could guide me on where to find the valve spring tool since Kirban doesn't sell them now.
Thx in advance for some assistance !
Brian Cotton of Cottons performance may have a valve spring tool. I got one from him a few yrs ago . He may still make them
X2 on Cottons’ for the valve spring tool .
They might even have available the RollMaster Gold “IWIS” chain & timing set.
They come in standard size or undersized if your engine has been line bored or line honed
I have a valvespring tool from Bluegrass Performance ya can borrow. I prefer it to the rocker type.
I’m not familiar with this tool , but a quick google search shows it’s for an LS.
Doesn’t look like it will work on an LC2 🤷‍♂️
How dare you doubt me......JKJK :D :D :D I found it easier. Compress, use a magnet for keepers, release tension, change springs, & reverse for keepers. I also put an old spark plug wire with end cut off to keep from losing valve.
Yes, I need the standard size. DOn't see them on the website but will call tomorrow. Any other venders that might have these in stock?
Where are you located? I'm in Oklahoma, might work out better to borrow and pay for shipping.
Appreciate the kindness.
Full Throttle, RJC Racing, TA Performance
(just to name a few)
Didn't see them listed on TA Perf, but will call tomorrow. Full throttle out of stock and never could get Jason on the phone to check.
I got mine from TA Performance.
They were the only vendor that said if it didn’t fit , they’d take it back & swap out to an undersized timing set (as long as it was only installed for mock up).
Tend to not forget Mike from being so accommodating .
I'm replacing my factory timing set, so standard is what I need, correct?
I also have the Bluegrass Performance valve spring tool. They've made plenty of versions of them, including for our Buick V6.
Way too many folks using that "rocker style" tool and not paying attention to what they are doing whereas the extension they're using ends up tearing really nice hood pads.
Sometimes it's too long of a pipe extension handle that may have worked great for cylinders 1 and 2 springs, but tore into the hood pad when working closer to the firewall. They're just not paying attention to the angle of the hood and the reduced contact height the closer you get to the firewall.
And there are the folks with worn lift supports (hood shocks) using too short of a broom stick to support the hood so they tear the hood pad.
Sadly, there's plenty of valve spring youtube "how to" videos showing how to tear up your hood pad as part of the process.
remember to check your valve springs out of the box and confirm your installed height pressure (need shims?) - but that's a whole other topic.
