MAP Question 3 Bar
salvageV6
Daily Driver
Anyone know the voltage range of a 3 bar map sensor.
Is it like .2 to 4.7 volts scale, or .25 to 4.75 etc.
What's the published range of operation. :)
TIA :cool:
The GM maps are all 0-5V out so for a 3 bar sensor 0 volts = 0 bar and 5 V = 3 bar, while for a 2 bar sensor 0 V = 0 bar and 5 V = 2 bar.
I've never seen anything from GM listing the exact range.
But, I fired up my bench a put a meter on the MAP signal line.
20 K/Pa = 300 mv
300 K/Pa = 4.59v
I do recall reading it had an range of 20-300 K/Pa.
But, I don't run 9s so I shouldn't be taken, seriously. :)
I prefer real data to bench racing. ;)
Not sure why anyone has to run 9's 10's or even 11's to fire up the voltmeter. :)
Thanks, I thought that might be the range very few electronics devices go rail to rail.
Gonna try the Motorola MPX series devices to build a good MAP device for about $25.
Start with a nice LED boost gauge first.
Just wanted to see if the range was the same or close to the GM device.
It is. :cool:
Originally posted by salvageV6
I
If you want some know points say 150 K/Pa, equal what voltage just tell me what you need.
Originally posted by wagon
http://www.kcsaab.com/aquamist/website/sl/plist/pics/mapm/mapm.html
http://www.kcsaab.com/aquamist/website/sl/plist/frm.html
This lists the 2 and 3 bar map voltage readings, it also shows a different brand with the same graph. Just click on the green check mark next to the item.
Hmm, it lists the max output as 4.7, yet in the graph 300 K/Pa is 5v.
Since I don't run 9's, I'll let others ask the guestion, *How can that be?*.
It also doesn't jive with the min output spec..
Max output is 4.8 volts. 0 PSI is 1.6 approx. see the GM sensors all read a little different. Yes they do...
You cannot feed 5 volts and get 5 output. There is loss.
So its called a 0-5volt sensor when actually its not.
Want to duplicate a 3 bar, buy one and graph the results. Then match yours to that. Easy. And its only 29.4 PSI technically.
Its all a relative thing.
Buy one?
You gotta be kidding, WAY overpriced. :eek:
Not critical to my applications either. ;)
